When I start my car it jumps up to 3000 rpms, after a few seconds it drops to about 2600, should be around 600-800. I took the throttle body off cleaned it, took the IAC off cleaned it and tested it and moves slightly, from what I am told thats all it is supposed to move. I also sprayed carb cleaner around vacuum lines, manifold and everywhere else I could think of to check for leaks. I am out of ideas. If you have any it would be a big help. Thanks, Jim
Oct 21, 2009 at 6:40 PM
