2001 Saturn SC2
2001 SATURN SC2
140,000 MILES • 4 CYL • FWD • MANUAL
CAMPBELL960
my 2001 sc2 was in a rear end accident .after it was repaired it wouldnt start.the body comp fuses were blown.i replaced the computer under the hood now it starts but stalls after 5 secs.i have no warning lightsor gauges.
Jan 25, 2010 at 11:57 AM
SATURNTECH9
  • 30,869 POSTS
first off thank u so much for the donation it really helps keep this site going.so u were rear ended and then ur body fuse and pcm fuse was blown?is there any fuses blowing now?what led u to replace the computer?also did u get a junk yard one?a new one?did u ever have the computers programed from the dealer?please let me know so i can better help u.
Jan 25, 2010 at 2:05 PM
CAMPBELL960
used computer..never had it programmed.i believed it was the comp because i had no fuel or sparkand now i do.no fuses blowing now i replaced all of them.right now everything works exept the warning lights and gauges.the warning lites come on if i pull the body comp fuse
Jan 25, 2010 at 2:39 PM
SATURNTECH9
  • 30,869 POSTS
That's strange that a rear collision caused ur computer to go bad.I could see blowing fuses because u have pinched wires.so u know u have 40-50psi fuel pressure u tested that with a fuel pressure gauge?does the car start at all?when u changed the computer was it the same yr sc2 sAme part number manual transmission all that?
Jan 25, 2010 at 4:20 PM
