1999 Saturn SC2 Front Wheel Bearings
1999 SATURN SC2
156,000 MILES • 4 CYL • FWD • MANUAL
DETAYLOR07
I need to replace the front wheel bearings on both sides. I need to do it with minimum expense, so I would like to do it myself. My question is- is the bearing a loose enough fit that I can remove the old one and install the new one on the car, do I need to remove the hub so I can use an arbor press, or is it better to buy a complete hub? If I can do it myself, can you provide any info I would need?
Thanks,
Dave Taylor
Apr 29, 2009 at 2:22 PM
MMPRINCE4000
  • 8,548 POSTS
You will have to press the bearings out and in, if you have a press, you will have to remove the knuckle and hub.
Apr 30, 2009 at 6:37 AM
