1999 Saturn SC2 Brakes Dragging
1999 SATURN SC2
195,000 MILES • 4 CYL • FWD • MANUAL
MARKSTANPHILL
Just replaced Brake pads, machined rotors, and Drivers caliper. When the brakes heat up, pedal becomes stiff (travels only 1/2 inch or so) front brakes grab tight, back will still free wheel when off the ground. what could be the issue here, at a loss...
Sep 7, 2010 at 10:31 AM
SATURNTECH9
  • 30,869 POSTS
So did you replace your drivers side caliper?If so why?Also you said your brake pedal becomes stiff and only moves a 1/2" do you mean a hard pedal?If so sound's like your power brake booster isn't working.Make sure your getting a good source of vacuum to it when the pedal get's hard and that your brake booster is holding vacuum.
Sep 7, 2010 at 12:12 PM
