sorry i forgot about adding what to check to help ur mileage so here it is. It is no secret gas prices are up and putting a big pinch on our pocket books. Car maintenance and driving habits significantly affect fuel economy. Here are a few tips to help you get the most for your buck. First, check the air pressure in your car's tires. Most vehicle tire pressure recommendations are located on a sticker in the driver's door jam or on the side wall of the tire. While tire and car manufacturers recommend a prescribed tire pressure, it has been shown that slightly more tire pressure is optimal for achieving higher fuel economy by reducing rolling resistance. Some hybrid cars are manufactured with tires that can hold up to 55 P.S.I. as compared with the usual 32 P.S.I. For safety and better gas mileage always keep your tires properly inflated. Next, analyze your driving habits. Do you take off quickly from a stop? Try easing into the throttle and allow the vehicle to accelerate slowly. Observe the traffic and signals in front of you. If a stop is imminent release the gas pedal and allow the car to coast the remainder of the distance before using the brakes. Proper maintenance of your car's engine is essential for optimum performance. If your engine is misfiring it will decrease mileage. If the engine oil and filter changes have been neglected it will cause additional friction inside the engine and hinder the performance and gas mileage. Finally, remove all un-necessary objects from the car, added weight can decease mileage also inspect your engine service records and perform a tune up or oil change as recommended. Following these gas saving tips can increase your mileage and save you money.also i would check ur spark plugs make sure there not worn out or gaped over .040".have u ever changed ur fuel filter?do u keep up on ur transmission services oil changes etc?do u have any engine trouble codes?have u had it checked for engine trouble codes?let me know.
Jan 27, 2010 at 12:33 PM
