1998 Saturn SC2
1998 SATURN SC2
DEADWOOD77
Engine Mechanical problem
1998 Saturn SC2 4 cyl Front Wheel Drive Automatic
can you replace the o rings without replacing the value cover gasket
Aug 14, 2010 at 2:11 PM
SATURNTECH9
  • 30,869 POSTS
Are you talking about the seal that keep's oil from going into the spark plug hole's?That goes onto the valve cover gasket?If that's what your talking about then you might as replace the whole gasket and not just part of it.It's not that hard to change just pull the old one out and put the new one in.Also when you buy the gasket you get the whole gasket anyway's.Also there is a trick you have to do when you remove the gasket if you don't do it then it will leak oil real bad.
Aug 14, 2010 at 4:24 PM
