Interior problem
1997 Saturn SC2
Ok, I have written in about this before, so I went to the Pick'n'Pull in local area and pulled the Master Control Switch and both Window regulators from a similar '97 saturn, installed the switch and drivers side regulator today.
I have power indication on the Master Control Switch, and power going to the window motor in the new regulator.
However, I still have nothing, the window will not raise or lower. I still have the passenger side regulator to replace, should I install that side regulator and see if the switch works first before I assume the motor on the used drivers side regulator is bad?
Or, should I go to pep boys, buy a new motor for the window, plug it in and test it to see if it works first.
The big question is this - how do I know if it is the motor or the control switch?
If the control switch gives me a power signal using a tester, that shows it works, right? and thus the only solution is the motor is bad in the window?
1997 Saturn SC2
Sep 12, 2010 at 8:47 PM
