1997 Saturn SC2 timing
1997 SATURN SC2
133,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNJONH
  • 5 POSTS
how to set the timing
Oct 7, 2010 at 8:02 PM
SATURNTECH9
  • 30,869 POSTS
Are you looking for the timing chain timing?
Oct 7, 2010 at 8:12 PM
JOHNJONH
  • 5 POSTS
[quote:51fc32673b="johnjonh"]Engine Mechanical problem
1997 Saturn SC2 4 cyl Two Wheel Drive Automatic 133000 miles
how to set the timing[/quote:51fc32673b]i never did get the answer
Oct 7, 2010 at 8:13 PM
SATURNTECH9
  • 30,869 POSTS
I asked you if your talking about the timing chain timing?If you give me answer to my question then i can get you a answer.
Oct 7, 2010 at 8:25 PM
JOHNJONH
  • 5 POSTS
yes
Oct 7, 2010 at 8:35 PM
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_1997_SC2_timing_marks_part1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_1997_SC2_timing_marks_part2_1.jpg
CAUTION: Excess slack in the chain must be kept to the chain tensioner side (movable guide) of the cylinder block when installing timing chain or the camshaft sprockets will not be correctly timed to the crankshaft sprocket. 6. Make sure the silver colored link plates are located over the pip mark on the cam sprockets only. The crankshaft sprocket tooth must be pointed directly downward at the 6 o'clock position between the two silver colored links. The pip mark on the crankshaft sprocket will be aligned with the timing mark on the cylinder block. There you go.
Oct 7, 2010 at 8:52 PM
JOHNJONH
  • 5 POSTS
hello i set the timing the same way you should me on the diagram but it seem to be dumping alot of gas and the car wont start
Oct 10, 2010 at 9:51 AM
SATURNTECH9
  • 30,869 POSTS
So why were you replacing the timing chain to begin with?was it dumping too much gas before you changed the timing chain?
Oct 10, 2010 at 10:51 AM
JOHNJONH
  • 5 POSTS
no it was a head put on first
Oct 11, 2010 at 8:22 AM
SATURNTECH9
  • 30,869 POSTS
So you replaced the head or head gasket?What happened there?Why did you have to do that?Was it flooding the engine before that?Also do you have any code's?What is the compression on each cylinder?I need to know all the detail's because i'm not there and don't know the history of the car.Do you have spark?WHat is your fuel pressure?
Oct 11, 2010 at 12:40 PM
