When I start the car if you don't have the throttle going it will not start at all. Most of the time this doesn't help anyway. It turns over no problem just doesn't fire and if it does it idles real low unless you are giving feathering gas. Runs rough idling even dieing out sometimes. The RPM's will go sky high and then bottom out and car will die. Have changed plugs and fuel filter and air filter. Have read alot of forums and there are a few things that people say this could be. Crank sensor or ignition module. Anything will help.
Nov 30, 2009 at 6:31 PM
