1997 Saturn SC2 serpentine tensioner
1997 SATURN SC2
170,000 MILES • 4 CYL • FWD • MANUAL
were are the bolts located to remove the tensioner
Feb 27, 2010 at 7:49 AM
SATURNTECH9
  • 30,869 POSTS
The best way to get to the tensior and the bolts is etheir remove or turn the passenger wheel.remove the passenger splash shield support the engine by putting a piece of wood under the oil pan with a jack remove the upper mount Jack the engine up take the belt off then u can get to the top bolt then let the engine down and remove the bottom bolt thru the side an the tensior thru there.put the new tenisor in and put everything together let me know how it goes.
Feb 27, 2010 at 9:01 AM
