Electrical problem
1997 Saturn SC2 4 cyl Two Wheel Drive Manual
Here is my question:
I have a 1997 Saturn SC 2, 2 door coupe, and the drivers window motor locked up.
It is stuck in the lowered position.
What is the best way to get the window back in the raised position, secured so it will not fall back into the lowered position.
The motor locked up and has not moved since. I do not have the means (money) to replace the motor. All I want is to raise the window back up again. I will replace the window motor later.
I see two options:
Remove the window from the control base and tape it in place, or...
Open the door paneling, remove the window motor regulator, unlock the motor (I would guess remove the motor cover and unscrew the control rod until the motor is loose), change the motor position to raised position and reinstall the regulator in the door.
I think the 2nd option is the most secure, and since the motor won't work anyway the window will stay up.
Is the 2nd option the best?
I see two options:
Aug 30, 2010 at 4:03 PM
