1997 Saturn SC2 Cooling fan will not shut off.
1997 SATURN SC2
140,000 MILES • 4 CYL • FWD • AUTOMATIC
CRAIGER43050
My cooling fan has begun to run constantly. It kicks on as soon as I start the engine. The thermostat appears to be functioning properly, not quite sure where to start problem checking. Thank you.
Jun 8, 2009 at 7:50 PM
SATURNGUY721
  • 16 POSTS
The control for a cooling fan is also the coolant temp sensor. This may be bad, check it and the wiring. If you unplug it it should come off , but fix it because your car will overheat if operated with out it.
Dec 20, 2009 at 11:42 PM
