PCM is dumping monitor codes so fails smog. Car does not idle when cold and stalls when warm. EGR valve is OK. Collant fan does not work. Milage has dropped significantly. Their are 0 codes when check computer. Is it possible that the PCM needs replacing?
Jan 14, 2010 at 10:25 AM
