#1 and #4 cylinders not firing. Thought it was the coil (since there are 2 of them) and it did not fix the problem. I switch the coils only to have the same results of #1 and #4 not firing. I then replaced the module hoping that it was the problem. Well..it did not fix it. I am not very familiar with Saturns ( I was a Honda Tech) so I do not even know where the PCM is located. Is the PCM the next thing to replace?
I am going to borrow an OBD to pull the codes later, but if anyone has experienced this delima, I would appreciate any help!
Apr 30, 2010 at 2:38 PM
