Engine Mechanical problem
1996 Saturn SC2 4 cyl Front Wheel Drive Manual 149,xx miles
I just bought this car, and the check engine light has been on I scanned it and it's that map sensor code, and I replace the sensor and check the vaccum holes and intake, and for the life of me I can't figure out the problem.. I'm to the point of taking it in and paying to get it fixed, which I never do.. Can help at all? Could it be because of a value cover gasket leak? When you pull the plug wire and look down in there, there is oil, the guy before me said he changed the gasket but clear he didn't do it right, could that have anything to do with the code? I really need your help here, thank you.
Aug 2, 2010 at 11:01 AM
