I noticed that oil was leaking into cylinder 1 and i would normally just take out the spark plug and let it drain through, start my car, and it would fix the problem. Had this problem for a couple months, and now the oil isnt leaking into the cylinder, I can actually see it on the exterior of the engine. I replaced the valve cover gasket and that did not fix the problem, Any ideas?
Also, Theres a rod protruding through the carpet by the rear speakers, im guessing a bushing?? It makes A LOT of noise when going over any bump so I try to avoid any bumps... I have heard that I can jack the car up and take the rod/bushing, whatever it is, out and replace it with a new one, or used from another model of the same car. Any ideas of if this is true, or how I would fix it? I heard that I may have to take out the rear glass?
May 14, 2010 at 6:50 AM
