Which temp sensor did you replace the top one with one wire or the bottom one that has two wire's?
Sep 22, 2010 at 6:41 PM
RICHBLACKMORE
MEMBER
replaced the temp sensor with one wire
Sep 22, 2010 at 7:10 PM
SATURNTECH9
CERTIFIED EXPERT
The top one with one wire is for the gauge you needed to replace the bottom one with two wire's that one is for the pcm make sure you get a brass tipped one the plastic tipped one crack's.Also inspect the connector going to it if it's corroded you will have to replace that too.I would start by replacing that sensor that's the most likely cause.Let me know how it run's after you replace it there only like 10.
Sep 22, 2010 at 7:21 PM
RICHBLACKMORE
MEMBER
It's running fine now, thanks very much !
Sep 23, 2010 at 11:06 PM
SATURNTECH9
CERTIFIED EXPERT
Your welcome glad to hear it's running good now.Thank you for using 2carpros.
