1991 Saturn SC2 Water Pump
1991 SATURN SC2
SOUTHIESGIRL91
1991 Saturn SC2 Automatic 132000 miles
How hard is it to replace a water pump??
Jul 12, 2010 at 2:04 AM
1.Disconnect battery ground cable, then drain coolant.
2.Raise and support vehicle.
3.Remove right wheel assembly, then inner wheelwell splash shield.
4.Remove A/C compressor attaching bolts, then position aside.
5.Place one inch wood block between crankshaft and water pump pulley, then remove water pump bolts and allow pulley to hang on pump hub.
6.Remove water pump attaching bolts, then remove water pump and discard gasket.
7.Reverse procedure to install. Tighten water pump bolts to specification in criss-cross pattern.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Jul 12, 2010 at 2:10 AM
