2001 Saturn SC1 engine code light
2001 SATURN SC1
148,000 MILES • 4 CYL • FWD • AUTOMATIC
PSONY2000
Engine light came on. obd11 read gear 2 ratio.
car will not go in reverse gear. when driving there is an abrupt shift when slowing down or accelerating.
Sep 7, 2010 at 11:14 AM
SATURNTECH9
  • 30,869 POSTS
The first thing i would check is if your input shaft nut on your transmission is loose.Then i would Check the min and max line pressure of your transmission.Then i would air check your clutches in your transmission.
Sep 7, 2010 at 12:07 PM
