1998 Saturn SC1 Milky color in transmission fluid...
1998 SATURN SC1
288,000 MILES • 4 CYL • FWD • MANUAL
ADPATTON89
My transmission was leaking fluid from one of the seals so I had taken it off to put on a new seal. When I did this I noticed that some of the fluid inside had a milky white color. I didn't notice any metal shavings or fine particles in it. Any ideas on what might be causing this?
May 4, 2010 at 12:00 PM
SATURNTECH9
  • 30,869 POSTS
[quote:c95bfdf1e9="adpatton89"]Transmission problem
1998 Saturn SC1 4 cyl Front Wheel Drive Manual 288000 miles
My transmission was leaking fluid from one of the seals so I had taken it off to put on a new seal. When I did this I noticed that some of the fluid inside had a milky white color. I didn't notice any metal shavings or fine particles in it. Any ideas on what might be causing this?[/quote:c95bfdf1e9]
milky white color usually means u have water in the fluid could have happened over time and not changing the fluid regularly.go ahead and change the fluid which u should have done when u change the seal it takes transmission fluid dex 3.does the transmission make any wierd noises?let me know how it goes.
May 4, 2010 at 12:47 PM
SATURNTECH9
  • 30,869 POSTS
U were asking a question at the end of ur repution point post it sounded like.u said I also don't know how to get?let me know so I can help u out with that one.
May 5, 2010 at 12:00 PM
ADPATTON89
[quote:06495d8501="saturntech9"]U were asking a question at the end of ur repution point post it sounded like.u said I also don't know how to get?let me know so I can help u out with that one.[/quote:06495d8501]
oh, I was saying I dont know how to get points. I only had one point to give you, but I dont know how to get more points to give to you or other people in the future.
May 5, 2010 at 12:32 PM
SATURNTECH9
  • 30,869 POSTS
Points are earned by asking or answering questions. They can also be given to another member by giving them a vote and how ever many points they wish to give away. Let me know if u have anymore questions.
May 5, 2010 at 3:40 PM
