Look at your key is it all worn out?Also do you have another key to try to see if that one work's.Have you tried moving the steering wheel while trying to turn the key?You could also try lightly tapping on the cylinder with a hammer and then try turn it.If you can get the key to turn to the acc position you can replace just the cylinder.If not you have to replace the cylinder and ignition housing.Let me know how it goes.
Jun 18, 2010 at 3:04 PM
