i am showing code p732 and have no reverse except first time you use it after that no reverse the rest of the day,what do you think?
Nov 5, 2009 at 9:56 AM
SATURNTECH9
CERTIFIED EXPERT
well the code u have is for second gear ratio and reverse uses second gear clutch pack so u could have a a bad second gear piston not holding pressure or loose input shaft nut theres a couple of things those are the first two that come to mind.u would have to have it checked out by someone that new what they were doing?hope this helps.
louie
