1996 Saturn SC1 higher rpm when braking
1996 SATURN SC1
ANGIEEM03
Brakes problem
1996 Saturn SC1 Automatic 98000 miles
For the last week the rpm on my car has gone up whenever I brake. If I'm coasting and the arrow is pointing to 1 rpm, as soon as I brake it will raise to at lease 2rpm, sometimes even 3.
The brakes still feel the same; it doesn't feel like it's fighting to accelerate, but the engine sounds like it's revving.
Nov 30, 2009 at 10:06 AM
SATURNTECH9
  • 30,869 POSTS
what if ur at idle in park and step on the brake will it raise the idle up?let me know.
louie
Nov 30, 2009 at 11:06 AM
ANGIEEM03
Not really. It moves slightly but doesn't make the revving noise or move up significantly like when I'm driving then brake.
...I also noticed my car does the revving noise and goes to a higher rpm when I first start it up, before i touch the gas or brake or shift to drive... but it goes right back down in a second.
Nov 30, 2009 at 4:14 PM
SATURNTECH9
  • 30,869 POSTS
higher rpms when starting are normal its part of the starting process.it doesn't make sense that when u brake and the rpms go up but u can't feel the car pulling.i tried it on my 99 sl2 just touched the gas while braking to recreate ur condition and i could feeling it pulling and would make it harder for u to stop.i was thinking u might have a bad brake booster leaking vaccuum when u step on the brake causing a vaccuum leak i have seen that one before.do u have any codes?
louie
Dec 1, 2009 at 10:58 AM
