1996 Saturn SC1
1996 SATURN SC1
FALCON12
  • 5 POSTS
Engine Mechanical problem
1996 Saturn SC1 4 cyl Two Wheel Drive Automatic
MY CAR STARTS OK BUT WHEN I PUT IT IN REVERSE OR DRIVE IT DIES ON ME
Jul 30, 2010 at 10:13 AM
SATURNTECH9
  • 30,869 POSTS
Does it die instantly?Or does it stumble and die?Also what code's do you have?
Jul 30, 2010 at 12:11 PM
FALCON12
  • 5 POSTS
it dies instantly and i dont heve any codes
Aug 2, 2010 at 12:16 PM
SATURNTECH9
  • 30,869 POSTS
Check all the fuse's especially the tcc fuse in the under hood fuse box for being blown.
Aug 2, 2010 at 1:02 PM
FALCON12
  • 5 POSTS
check all the fuses in both fuse panels still my car dies when i put it in gear
Aug 2, 2010 at 3:59 PM
SATURNTECH9
  • 30,869 POSTS
So all the fuse's were good especially the tcc fuse in the under hood fuse box?Also you checked for code's and there were none?How does it run in park?Can you rev it up smooth and does it idle smooth.
Aug 2, 2010 at 5:03 PM
FALCON12
  • 5 POSTS
in park it runs smooth like theres nothing wrong i rev it up and it runs smooth
Aug 2, 2010 at 5:42 PM
SATURNTECH9
  • 30,869 POSTS
If it idles smooth too then i would say something is going on with your transmission possibly your torque convertor staying locked up all the time.
Aug 2, 2010 at 5:46 PM
FALCON12
  • 5 POSTS
can it be a tcc solenoid
Aug 5, 2010 at 11:45 AM
SATURNTECH9
  • 30,869 POSTS
See if you can rent a scan tool and get some code's to help you find the problem.That's where i would start.
Aug 5, 2010 at 2:41 PM
