I recently changed my starter and I am still having the same problem. My starter seems to turn the engine over fine when it’s cold though it has done it once in a while but it is more prevalent when warm. The issue is the starter makes a sound like it is turning over but the engine is not. It seems like the starter drive is slipping but I know it’s good. The sound is not a click, click, and clicks either. The battery is original, so I am thinking change it anyway but I had it tested at a parts store and they said it was fine. It seems like the starter drive gets stuck or does not engage into the flywheel but i know it is spinning . If I turn the key off again and back on it will eventually turn the engine over and start. This issue does not happen every time either. Any suggestions would be great.
May 27, 2009 at 7:33 AM
