There is an existing thread on the same problem but I was unable to get it right using that info.
When I press the brake, with the drum on, the front piston pops out and leaks. I observed the tendency for the front shoe to get behind the piston but that did not happen this time. I also checked that the bottom of the shoes are fitted inside the plate at the bottom.
I replaced the cylinder with a known good one and the same results.
I successfully did this job a few months ago but must have left too much drag because the shoes on that side burned up. The soes are also nearly worn out and the drum is terrible.
I have new drums on the way and shoes to install but I don't want to use them until I get to the bottom of this problem, otherwise I will contaminate another set of shoes.
I am of course cursing Saturn for not providing slots in the pistons to securely hold the shoes, but that gives me no solution..
I know it was working fine until the original shoes wore down. There was no trouble other than grinding.
Anyone suffered through this can help me? I have worked on it for two whole days, trying everything but new shoes.
Notice, in the pictures the adjuster piece is not engaged as it should be, but this is not the problem.
Jan 9, 2020 at 3:47 PM
