drain coolant and remove inlet and outlet hoses from housing. then remove housing bolts and housing will come off. thermostat and gasket can then be removed and replaced.
Here is a guide to show you what you are in for when doing the job with diagrams below showing how it is on your car.
Cheers
Oct 11, 2010 at 10:30 PM
