Warning Light
SATURN
RPONTIN
Saturn. 2004. My sister-in-law has called me. She is about 120 miles fro home and she said a warning light with a wrench symbol as come on twice. What does this light indicate? She is on a cruise at the moment. Will it be safe to drive home before she goes to her dealer. Thanks for your help.
Mar 19, 2007 at 8:20 AM
AMNORTO
  • 17 POSTS
Well that symbol could mean a bunch of things. when it came on in my grandfathers car I found out it was a fuse and just replaced it. So try checking the fuse.
Mar 19, 2007 at 11:24 PM
PEPPERMRJ
  • 1,158 POSTS
[quote:b3bbb8db31="rpontin"]Saturn. 2004. My sister-in-law has called me. She is about 120 miles fro home and she said a warning light with a wrench symbol as come on twice. What does this light indicate? She is on a cruise at the moment. Will it be safe to drive home before she goes to her dealer. Thanks for your help.[/quote:b3bbb8db31]
If I remeber correctly the light means that you should have your vehicle serviced asap. If the light is blinking it is more serious.
The light means that there has been a fualt detected by the computer with regards to the engine, mainly emmision related. It could be as simply as a loose gas cap or more much more.
Call the dealer and get there opinion to be certain.
Wish Sis good luck and let us know. :)
Mar 20, 2007 at 5:04 PM
MIKE H R
  • 3,094 POSTS
when she gets back from her cruise , before drive the 120 miles have her have the oil, transmission fluid, and fan belt checked, assuming there are no noises or knocking she would be able to drive the car home. did she tell you if the light blinked or just stayed on? if it blinked have her count the number of times { example, if it blinked twice then paused and then blinked once} that code tells what is the problem the computer is picking up, if it just stayed on the car would have to be checked as soon with a scanner.
Mar 20, 2007 at 5:23 PM
