Hi I have a '94 Saturn SL2 odometer reads 98k miles, though it stopped working probably about 60k miles ago. What can I do to get this working again?
The rear brakes (drum) squeek while braking, I've inspected the drums they look ok, I've replaced the shoes, squeeking remains.
Engine overheats while idle (sitting at stop lights, traffic, etc) I've replaced the radiator, as it popped because of this issue, I've replaced the thermostat, I've replaced the hoses, I've flushed the resevoir tank, I've replaced the Engine Temperature Coolant Sensor (the one to the fan, not the one to the PCM). The fan does not kick on idle, though it does work while the AC is turned on, or I can flip the AC on till the fan turns on, then turn the AC off, and the fan will remain on until the engine is at an acceptable temperature (3/8th of gauge).
Any help anyone can offer would be greatly appreciated (before I put the dang car in the shop!)
so frustrating...
so frustrating...
Feb 26, 2006 at 7:46 PM
