I'm putting speakers in my son's car.How can I unhook the lock from the rod behind the door panel?
Mar 7, 2007 at 3:42 PM
PEPPERMRJ
CERTIFIED EXPERT
Could be a PITA. Have you removed the door skin or inside panel? Are you trying to remove the rod at the interior lock button, the latch itself, the exterior lock cylinder, or the power lock solenoid?
Mar 11, 2007 at 9:31 PM
JERRYH59
MEMBER
I'm trying to remove the rod at the interior lock button.I got the rod to the door latch removed.I took a screw driver and worked it loose.
Mar 11, 2007 at 11:04 PM
PEPPERMRJ
CERTIFIED EXPERT
The rod goes into the lock button from the top down. You have to move it up to remove it.
Good luck and let us know. :)
Mar 12, 2007 at 7:41 PM
JERRYH59
MEMBER
I got the door panel off today. After I got the passenger door off. The driver side was a snap. Thanks for the help.
