code 19 and 26
1919 SATURN
THE_HYDROXIDE_CHILD
  • 82 POSTS
we are working on a 92 saturn dohc and when u start it the check engine lights comes on instantly.... code 19 and 26 are the only codes that show up about 1 to 2 mintes after running itll cut out and the the rpms will drop then die.... what do these codes mean if anyone can help me please thk you
May 2, 2007 at 12:51 PM
THE_HYDROXIDE_CHILD
  • 82 POSTS
ok i dunno how to explain this but im not the smartest person when it comes to reading those links u gave me so is there any way u could kinda dumb it down lol........
May 3, 2007 at 7:35 PM
WSCREATE
  • 59 POSTS
I am not familiar with code 19, but my code 26 is due to a faulty passive restraint control module. I have intermittent problems with the passenger side restraint... heard a clicking sound under the console near the gear shifter (that is where the prcm is located). Thus, my code 26 is most likely the prcm. However, code 26 has 8 or so different possible explanations.
For the code 26, follow these trouble shooting steps.
DTC 26 Trouble Shooting.
1. Turn key to the ON position.
2. Do the light come ON and the SES light shut off? If YES go to next step. If NO:
-Check circuit(s) for voltage (fuse), short to ground, open wire or bulb.
3. Ground ALDL A to B. Is coolant fan running? If YES go to next step. If NO:
-Check circuit for voltage, (fuse), or open. Coolant fan relay resistance 70-90 ohms.
4. Remove ALDL ground. Start engine. Turn on A/C.
5. Does A/C clutch operate? If YES go to next step. If NO:
-Check circuit for voltage, (fuse), or open. A/C relay resistance 70-90 ohms.
6. Does the speedometer operate correctly? If YES go to next step. If NO:
-Check circuit(s) for voltage (fuse), short to ground, or open wire.
7. Disconnect PCM and ground circuit 456.
8. Does upshift (man) or shift to D2 (auto 1991-1992) or traction control telltale light?
9. Measure voltage at circuits 428 and 435 at PCM harness connector.
10. Is voltage present on both circuits? If YES go to next step. If NO:
-Check circuit(s) for voltage(fuse)m short to ground, open wire or solenoid(s).
11. Key OFF. Measure resistance of EGR and EVAP canister purge solenoid. EGR
should be 20-50 ohms;EVAP canister should be 20-50 ohms.
12. Are solenoids within specification? If YES go to next step. If NO:
-Shorted solenoid(s).
13. Put vehicle on lift or on jackstands securely enough and high enough to allow
wheels to spin. Leave driver's sode door open, start vehicle, place in DRIVE and
slowly increas vehicle speed to 24 km/h (15 mph).
14. Does vehicle drivers belt move from A-pillar to the B-pillar? If YES go to next step. If NO:
-Check circuit 817 to passive restraint module for open or shorts.
-Is circuit 817 OK? If YES Check terminal tightness or passive restraint module. If NO:
-Repair circuit 817.
15. Reconnect PCM. Clear diagnostic trouble codes. Start engine.
16. Does DTC 26 reset? If NO go to next step. If YES:
-Terminal tightness or PCM.
17. Problem intermittent; see diagnostic aids
May 4, 2007 at 9:30 AM
PEPPERMRJ
  • 1,158 POSTS
[quote:851732752f="the_hydroxide_child"]ok i dunno how to explain this but im not the smartest person when it comes to reading those links u gave me so is there any way u could kinda dumb it down lol........[/quote:851732752f]
Hey the,
Know what ya mean. It is like learning a different language at first.
For the code 19, I would check the crankshaft position sensor by replacing it. Not very expensive and easy to replace. Let me know if you need instructions. I think this is what is causing the engine to shut down.
For code 26 Ws has it covered. The short story is that there is a problem with one of these four devices.
EGR solenoid
Coolant fan relay
A/C relay
Check the relays by swapping in known good ones clearing the codes and seeing if the code 26 comes back.
Good hunting and let us know. :)
peppermrj
May 5, 2007 at 4:21 PM
