Have a 97 saturn sl2, about 96k on it. Not sure of the engine size off hand. I had the catalytic converter replaced last fall after it broke, had the transmission flushed, thermostat replaced (along with some coil inside of there that cost a bundle), and had the oxygen sensor replaced a few months ago. That should have been done when the catalytic converter was done,but i wasn't told this. Well since i had the thermostat and coil replaced, my car runs hotter than it used to. It used to run about 1/4 of the temp gauge and now it runs at halfway almost instantly. If i get stuck in traffic or in a drive-thru, it starts getting hot and moving up toward the 3/4 mark. The fan will kick on but it worries me since my last car had a a problem and overheated, which resulted in HUGE problems that would have cost a bundle to fix (more than the car was worth). What else would cause a car to run this hot? Please help.
Apr 24, 2007 at 11:41 AM
