95 Saturn SL2 Misfiring
1995 SATURN
JOHNSIANEZ
  • 4 POSTS
Ok! I have a 95 saturn SL2 145,000 miles good maint. changed coils, spark plugs starter, and plug wires. The car starts fine but when put into gear the engine knocks and shakes alot. I checked all connections and even replaced the plugs and it stills does the same thing. Any help would be appreciated.
Dec 14, 2006 at 9:40 PM
BACKYARDMECHANIC
  • 337 POSTS
Have you checked for a vacuum leak. If there is no leak I would then check the timing. BYM :)
Dec 15, 2006 at 6:52 AM
J REDNECK
  • 5 POSTS
How do u go about checking the timing on it with no distibuter
Jan 1, 2007 at 9:11 PM
SERVICE WRITER
  • 9,123 POSTS
Coolant temp sensor very common on these and will cause a rough idle.
Jan 1, 2007 at 9:46 PM
J REDNECK
  • 5 POSTS
wher about is the coolant temp sensor located
Jan 1, 2007 at 9:50 PM
SERVICE WRITER
  • 9,123 POSTS
On the driver's side of the motor, plugged into the block. It's a small thing. If you get a sensor, you can match it up to the connector easy enough. Very quick to change. These are common enough, that even it wasn't the problem, I would want one on hand if I owned one again.
Jan 2, 2007 at 6:01 AM
