2005 Saturn Vue traction Light
2005 SATURN
KJJOHNSTON
Hi, I am hoping you can help me. I have a 2005 Saturn Vue with about 9250 miles on it. My problem started after having the car for about 6 months. It first started with what sounded like the Engine running when I was sitting still or in Park. I took it to Saturn to check, and they could not find the problem. About 6 months later, my Traction Light would come on when I was in Park. I once again took it to Saturn and at first they could not find anything wrong with the car. Saturn ran several tests and could not fnd anything wrong with the car. FINALLY they figured out that the Traction Light was coming on due to a bad ABS/Traction unit, in wich Saturn replaced for me. Promising that the light will not come on again. Well it started again about 1-2 weeks ago. I was in Park when the Traction Light would come on, however the light does not come on all the time. and now when the light comes on I can not push the traction light button to reset it. Nothing happens. So, once again I take the car back to Saturn, however this time they say there is nothing wrong with the car. My question to you is
Can you please let me know why this light is coming on, and what does it mean ??
Why when my car is contacted to the Diagnostic Machine it does not detect anything?
Jul 17, 2006 at 5:46 PM
MIKEYBDMAN
  • 623 POSTS
I have never delt with a saturn traction control system, but I do not believe that getting a low traction light, or the traction off light in park is normal.
If the dealer service department will not work on your car, then it is time to write a letter to the Saturn manegment team and see if they can motivate your dealer to fix your problem.
One thing that you can do is try to figure out what conditions cause the light, so you can duplicate them for the dealer. Things like parked on an incline, rainy out, engine hot, or cold. Just try and think of anything that can possibly help produce the problem when the dealer has the car for service.
Good luck.
Jul 17, 2006 at 6:09 PM
