2001 Other Saturn Models Idleing
2001 SATURN
150,000 MILES • 4 CYL • FWD • MANUAL
AHINDER3
My 2001 SL1 1.9l idles high. Just changed oil, filter, plugs & cleaned intake (which was full of carbon). Now it idles between 2 & 3 thousand rpm. Engine also runs very cold as if the thermostat is stuck open. Any pointers as where to look for the problem? Thanks.
Feb 22, 2008 at 9:49 PM
Idles high-could be vacuum leak/sticking throttle plate or kinked throttle cable-or a problem with the idle air control valve and throttle position sensor.
Cold engine -replace the thermostat
Feb 23, 2008 at 12:15 AM
