2000 Other Saturn Models Hi Beam Lite Switch
2000 SATURN
150,000 MILES • 4 CYL • FWD • AUTOMATIC
RON11
  • 4 POSTS
My 2000 L series has a high beam control on the turn indicator switch on the steering column. When turning on the indicator the high beams come on and stay on. After making the turn your high beams are on. You can hold the lever in and they will sometimes go off. But pulling the switch to turn off will not turn off high beams and in day lite I am driving with high beams on. However some times you can't turn off the lights when you turn off the car. You can try to wedge something in to hold the lever in place but it falls out and lites come on. Thus last night it drained the battery. Saturn dealer now out of business. Faulty switch? loose switch?, other problem?
Oct 9, 2009 at 2:23 PM
KHLOW2008
  • 41,814 POSTS
Hi Ron11,
Yes, the symptoms do indicate a faulty light switch. Too bad there are no dealers around to help you. Check out the local parts store to see if they can supply you the part.
Oct 10, 2009 at 8:51 AM
