2000 L-series brakes
2000 SATURN
MAIVOY
2000 Saturn L200 wagon 65,000 miles 3.0L 6cyl.
changed both rear calipers and rotors(removed hardware from loaded calipers to lubricate).front rotors and pads were changed 6mos. ago(removed hardware to clean and re-lubricate). after bleeding system i was not happy with pedal (it want half-way to floor to stop and not well). took car to mech. and he cross bleed system for me. pedal is still the same(stops mushy unless you double pump them,then stops like new). if you hold the pedal down it does not creep to the floor(could this still be a master cyl. issue) please advise (its dads car) and i think he has been driving it like that prior to repairs thanks
May 20, 2007 at 8:39 AM
SERVICE WRITER
  • 9,123 POSTS
You can pull the lines on the master and plug them, it should give you a hard pedal when you step on it .
May 20, 2007 at 9:32 AM
