[quote:92fba745d0="trooz2"]I changed the spark plugs about 3 months ago and was change the wires today when I pulled the wire off there was fluid inside. What do you think is wrong? :shock:[/quote:92fba745d0]
Hello friend, i'm sure it's not a serious problem. More then likely, your problem is " tube isolators (aka: tube seals). The fix is to replace the valve cover gasket & "tube seals". You could purchase a VALVE COVER GASKET SET from the local auto parts & change it. If your wondering what "tube seals" look like, its 4 round rings connected in a straight line & it goes on top of the tubes where the spark plugs go into the engine. Hope this helps. Good luck!!!
Oct 6, 2007 at 2:17 PM
