1998 Other Saturn Models Starter fails when car is warm
1998 SATURN
150,000 MILES • 4 CYL • 2WD • MANUAL
BILLDOUCET
I have a 1998 Saturn SR2. It will start fine as long as the car has been sitting for at least 3 hours. If I drive it for more than 5 minutes and then try to restart it all I get is a "click" from the starter.
Luckily it's a standard so I've taken to starting it with a push.
Otherwise the car runs very well.
Any help will be very much appreciated.
Thanks
Sep 4, 2008 at 5:12 AM
Double check connections at the battery and starter.
Could mean a problem with the ignition switch/clutch switch/starter relay or the starter itself. Try this when it goes click-hold key at crank position and bang on the starter if it engages the engine replace the starter.
Sep 4, 2008 at 5:23 AM
