1998 Other Saturn Models 98 saturn sl2
1998 SATURN
173,000 MILES • 4 CYL • FWD • AUTOMATIC
ABLUEEYEDMALE
  • 6 POSTS
HI.i have a 1998 saturn sl2 and my question is.when i give the car a little gas it has a dead spot.would the tps be causing it? i put new plugs/wires/os sensor/motormounts.any help would be great.
Feb 12, 2008 at 4:41 PM
MASTERTECHTIM
  • 4,750 POSTS
it certainly could. to know for sure you would need to look at voltages on a scan tool and watch for it to drop out while accelerating.
Feb 12, 2008 at 4:47 PM
ABLUEEYEDMALE
  • 6 POSTS
ok thanks i will do that when i get up tomorrow if theres not 3 foot of snow
Feb 12, 2008 at 5:43 PM
ABLUEEYEDMALE
  • 6 POSTS
the problem was.Symptom: Hesitates under part throttle, may feel like an engine misfire, ignition system and fuel delivery system test good.
System: Emissions/PCM/Fuel, Engine Ignition
Codes: Possible P0300, P0301, P0304
Problem: The #1 and #4 Spark Plug Wires are reversed which causes the injector timing to be off by 180 degrees.
Test & Fix: Verify the correct Spark Plug Wire installation order of 4, 1, 2, 3
Feb 16, 2008 at 2:23 PM
