1997 Other Saturn Models Loss of Transmission Fluid!
1997 SATURN
LIVING4FIRE
  • 4 POSTS
Transmission problem
1997 Other Saturn Models Engine Size unknown Two Wheel Drive Automatic 89000 miles
Ok so i was out doing my own oil change today for the first time and when i got to the step of removing the old oil filter i found one that looked like it near the front of the car. I start to loosen it up and it leaks a lot so i thought that might be normal so i kept screwing and it kept flowing and it was a redish color so i was thinking..."OH NO, this isnt an oil filter!" after loosing a small amount of transmission fluid (im sure that is what it was, the filter type thing that i loosened said transmission on it and it was a redish fluid.) i tightened it and began to search for the true oil filter which i located just behind the oil pan. Anyways to my question. How do i go about checking my Transmission fluid levels and what type of transmission fluid do i use if i need to fill it up some...is all kinds universal or are there different kinds. Sorry for such lame question but i truly appreciate any honest answers. Thanks.
-Cory
(I have a saturn 1997 SL2)
Jan 2, 2008 at 8:54 PM
JUSTIN FREED
  • 87 POSTS
There is a dipstick specifically for the transmission. As you stand in front of the car looking into the engine compartment, the tranny dipstick will be to the right of where the oil dipstick is...just where the engine mates w/ the transmission.
The transmission must be hot (normal operating temp) when you check the level.
A 97 automatic will hold a total of 5.3 qts. The manufacturer recommends using DEXRON III Automatic Transmission Fluid.
Hope this helps!
Jan 3, 2008 at 8:03 PM
