1996 Other Saturn Models valve cover gasket replacement/bolt
1996 SATURN
18,000 MILES • 4 CYL • 2WD • MANUAL
BURNETTO
I am using a friends tools I need to know what are the 'exterior' and 'interior '(the one's near the injector cords) bolt sizes. And if there is a particular brand /style of gasket to use and if any 'prep' product shound be put down between the new gasket and the valve cover engine 'rim',?
Dec 24, 2007 at 12:58 PM
JUSTIN FREED
  • 87 POSTS
Not sure of the size..it'll just be hit or miss. It also depends on whether you have a single over head cam (SOHC) or dual over head cam (DOHC).
On a SOHC, you remove the two valve cover bolts (torx). On DOHC, there are 11 torx bolts that need to be removed.
Any decent quality gasket should suffice (like from a reputable auto parts store). Make sure the new gasket fits properly in its groove and you can use a bit of RTV sealant where the front cover contacts the cylinder head.
When reinstalling, make sure you tighten the valve cover bolts in the proper sequence (not much of a problem w/ a SOHC but on the DOHC, there is a definite tightening sequence). A reputable repair manual can be very valuable in these sortS of instances. Good luck!
Dec 27, 2007 at 7:16 PM
