1996 Other Saturn Models Fans won't work
1996 SATURN
ANNWILHELM
Heater problem
1996 Other Saturn Models 4 cyl Front Wheel Drive 174000 miles
I turn on the heat or air and the fan won't work. Compressor kicks in but no fan. When you press button for air the power light doesn't come on and no fan. Also when I press the button for rear defrost the power light doesn't come on and rear defrost doesn't work. The fans for the front defrost doesn't work either. Checked the fuse box under the hood and all fuses seemed fine. Is there maybe another fuse box in the car? CAn't find the owners manual.
Jan 6, 2010 at 8:01 PM
SATURNTECH9
  • 30,869 POSTS
under ur dash on the passenger side theres ur blower motor lets start by checking for power and ground ur b terminal purple wire should be power when u have the key to run postion and ur fan switch on.on terminal a u should have a good connection to groud lets start there.let me know what u find.
Jan 7, 2010 at 11:50 AM
