1995 Saturn SL2 Automatic Trans problem
1995 SATURN
UNEDUEX
I bought a 1995 Saturn SL2 (1.9 liter, 4 cyl) from a local dealership about a month ago. They told me they purchased it from a Saturn dealership (it was a trade-in for a new Saturn) and that it was in perfect working condition. My husband and I checked the car out, checked all the fluids, everything looked great and all the fluids were fine, no leaks of any kind (still).
Right away I noticed there was a transmission problem. Every car I have ever owned has had some kind of transmission problem, I swear sometimes I am cursed!
The problems: I don't know if this is common but when I am braking, the RPM's hop up to over 2k RPM's for just a second, this usually happens when I've braked below 20 MPH. The other problem is that sometimes when I am driving the car, it appears as if it gets "stuck" in a gear and it won't accelerate or switch gears, the RPM's go up very high and it takes a few moments for it to go to the correct gear. There are no grinding sounds when this happens, my last car (1985 Olds Delta 88 lt. ed) had a horrible grinding noise and shaking when it was driven. It sounds nothing like that, but it does sound as if the transmission is being taxed pretty badly when it gets stuck like that. Once I have slowed down and re-accelerated, the car is fine. It doesn't happen THAT frequently, but it does happen when I've been driving the car for a long period of time (45 minutes or more).
I was told by a friend that knows a little about cars that is sounds as if my transmission is slipping. Is this the case? I have not taken my car to a mechanic yet because I am afraid of the news!
Thanks in advance for the help.
Feb 21, 2007 at 8:56 AM
UNEDUEX
P.S. I have all the service records from the previous owner. I also forgot to mention that the Carfax was perfect and it is a 1-owner vehicle. I've gone through the service records and I have not seen any major repairs, just regular maintenance.
Feb 21, 2007 at 9:12 AM
2CARPRO JACK
  • 11,533 POSTS
HAve your tech scan the PCM for history and current codes. If the trans had a problem it will set a code and we can go from there
Feb 21, 2007 at 12:19 PM
UNEDUEX
Where would I take it to do something like that? I took the car to a transmission center but he just drove it around and said "it sounds fine".
Feb 21, 2007 at 2:55 PM
