1995 Other Saturn Models Idling problem
1995 SATURN
155,000 MILES • 4 CYL • FWD • AUTOMATIC
HAPPYHEATHEN
I own a 95 Saturn SL2 First time I start my car every morning it does fine, but after I've driven it once it will have this problem the rest of the day. When I start it, one of two things will happen, either it will just stall immediately, or it will rev high, to the 2k or 3k rpm range, then drop down low to below 1k, then will rev back up to the 2k-3k range again, and it will repeat this for a while and either stabilize, or stall. So far I have replaced the IAC valve, the TPS, Sparkplugs and fuel filter. Also the starter but I don't think that's relevant to the problem.
Dec 21, 2007 at 6:41 AM
MWITT
I have the same problem with my 95 SL1. When you start it up in the morniing for the first time it seems to rev higher and sometimes will rev up and then drop down, but after driving for awhile then the revs are very low and slow speeds and when you come to a stop or put it in park them the revs go way down and it stalls. Sometimes after stalling it won't start up until you push the gas pedal all the way to the floor then it fires up. Any thoughts?
Jan 10, 2008 at 8:25 PM
