1994 Other Saturn Models Flashing Warning Light
1994 SATURN
200,000 MILES • 4 CYL • FWD • MANUAL
DOGMOM
The coolant/temperature light flashes. The sensor and hoses were replaced a few years ago. Hoses were just replaced again. Water pump was also just replaced.
I did not drive it for some time because it was having problems holding fluid. System was presssure tested and hoses were replaced because someone put the wrong ones on. Coolant reservoir and radiator are fine. What would cause the light to flash? Please advise.
Jul 11, 2008 at 9:56 AM
MERLIN2021
  • 17,250 POSTS
Read your codes and I will look them up for you...
https://www.2carpros.com/forum/automotive_pictures/62217_GM_DLC95_Older_15.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
Jul 11, 2008 at 10:04 AM
