1994 Other Saturn Models engine shuts off when I press on Br
1994 SATURN
SKAUS2000
Electrical problem
1994 Other Saturn Models Two Wheel Drive Automatic 107000 miles
How do I find problem here.
My Car had a transmission leak. Filter which is located in front of transmission leaked out 3 qts of oil.
I replaced filter and fluid
The car will now shut off when I press on the brake.
It will also drop in RPM if I put on signal lights .
If I put on hazard lights it also drops in RPM
How do I find the source of this problem
Today for 3 hours the car ran fine but this evening when I pressed the brake pedal the car shut off.
And each time I start the car not if I press the brake pedal the engine will shut off.
Dec 12, 2007 at 9:09 PM
SKAUS2000
It will also drop in RPM if I put on signls lights .
Dec 12, 2007 at 9:34 PM
