Have a bad window motor. Can only access by removing outer door panel. What's the trick to disconnecting linkage from door handle. handle is only thing preventing removal of entire panel. Side mirror and inside door panel are also removed. Also, what's more irritating is the high idle when coasting. Idle never returns to normal when coasting on freeway. Takes time to spool down. Idle is around 1200 when parked. but when i let off accelerator idle drops very slowly while on freeway. Going to only get 10000 miles out of my brakes at this rate. I've even removed carbon buildup from inside throttle body and helped slightly. Idle screw is completey back off. Thank you!
Jan 3, 2008 at 4:03 PM
