I have a 1992 saturn sl1, and[u:a6957298b0] i have replaced the oil pump [/u:a6957298b0]and checked the oil pressure relieve valve =(I used a pry bar to pop it out),and the valve is good!. I checked the 'o'-rings and they look good. and I put it all back together and it still ticks!.
I took it to a saturn dealer! and they said it was not getting a oil pressure reading!?. and that they would charge me $550.00 to check it out more. by dropping the oil pan and removeing the front cover!!.
after what i told them what i replaced and checked??. So is it likely a pluged oil passage? or would it be a 'o'-ring problem!?. or would it be the
crank shaft seal!?. I also took it out!, used a srcew=driver to remove it, it looked a little worn!?.[/b]
May 6, 2006 at 1:09 AM
