Under hard acceleration as during passing or climbing steep grades the transmission will not shift properly. What normally happens is that the RPM's go up but the car does not go any faster as if the transmission is slipping. It also will not shift unless you let your foot off the gas. Could this be a low fluid level? Plugged filter? Something worse?
Where do you check the fluid level and where do you add additional fluid?
Thanks, Steve
Thanks, Steve
Jan 2, 2008 at 12:20 PM
